What video card to get?
ZoomZoom
I'm looking to build a budget PC.
The only games really play are on MAME. I need something that will play all those games smooth withour problems. I also need s-video out to hook up to my TV. What's the best bang for my buck?
Well it would definitely help if you knew which format or slot you would like or have.
AGP
or
PCI-Express.
Seriously though your post is beyond vague.
What is MAME? You must have some type of price range. Do you plan on upgrading in a year or two?
I would think that anything with s-video out and a Radeon 9800Pro / Geforce 6600GT or better would be able to run it plenty good. Mame isn't that demanding.
PCI video cards are cheap. You want somewhat futureproof, get a pci-e card.
PCI-Express a 256MB
Price Range - $100.00 - $350.00
Preferred Brand ATI, Power color, Gigabyte
must be a ALL-IN-WONDER
AGP
or
PCI-Express.
I don't know the differneces between the two.
Emulator that plays arcade games. My current P3 & Voodoo3 card can't hanlde a lot of the games on MAME such as Mortal Kombat. No, I don't plan on upgrading.
MAME: Multiple Arcade Machine Emulator
MAME doesn't benefit from the video card as much as it will from a quicker processor. MAME will only use VERY minimal graphical effects to smooth out the pixellation on the classic graphics, while the audio and rest of the game is processed solely by the processor.
Basically, that voodoo3 card you've got will be fine for MAME (if you'd like to hang on to it), but for s-video out that 6200 (pci, agp, or pci-e) would be MORE than enough. The most important aspects for this new MAME machine are the CPU and possibly RAM.
If he still plays his games through MAME, I think the last thing he needs is something "future-proof."
Hahah well I assume if he is using such a card its either through PCI or AGP.
I hate to be the bearer of bad news, but it's usually better for people to help you when you at least know the majority, if not all the specs of your setup.
We aren't mind readers you know...
he has a p3, not much else needed to know. he obviously cant use pci-e, i dont know if that voodoo 3 is a pci or agp card, best way to find out is to see if the connector the card is in is either white or a different color. A very cheap celeron d or sempron rig, around 160 for cpu+ram+mobo will be enough to play mame, and you can get a cheap pci video card for s-video.
So what AMD processor & mb do you recommend? I'd like to get at least the 3400+, but I'm not looking to spend a fortune. Will 512MB DDR RAM suffice?
