Well I have some dell promotional gift cards to use, since I didn't know that you can't combine them since I was planning to buy a PS3.
1x $150 promotional gift card
2x $100 promotional gift card
1x $75 recession coupon
2x $25 coupon
(ALL FOR DELL)
I'll most likely use a $100 gift,$25 coupon, and whatever is leftover I will pay with my own money. (Saved up $190-- hehe
) I'm looking to play COD4 on a 1680x1050 resolution monitor (Samsung 22" 220wm) and wanted to ask for ya'lls input in what to get. Here are some videocards that I am looking over:
$259.99 ($229.99 AR)- Evga 8800 GT Superclocked 512 MB
$232- Evga 9600 GT Superclocked 512 MB
*theres the hd 3850 and hd 3870 also but its even more overpriced at dell
So I'm debating over those two videocards. I know both can max out COD4 @ 1680x1050 and that the 8800gt will most likely last longer because of the higher stream processors but I'm also wondering if I should get like a 8600gt/8600gts instead and step to either of those cards later since they are cheaper elsewhere from dell. So should I go with either of the 8800gt/9600gt cards or should I go with 8600gt/gts and step up later?
2x $25 coupon
(ALL FOR DELL)
