rivatuner is not bad either, you can usually get about 5-10 extra % using riva rather than coolbits if you disable rivas clockprotection feature thing.
I just played Halo with it like that, no artifacts at all. But I am unsure the clocks are sticking, I mean i did them in power user, but upon rennot they were back to default. The Performance3D settings stayed, though. I do not like this overclocker.
I tried CoolBits. It detects the setting I used with RivaTuner 581/1018. I set CoolBits to 583/1.18 and all is fine.
thsoe xfx cards are AWESOME! i have one, and with my icestorm, i can get the core up to 600 with the mem at 1.22. they are hands down the best 6600gt out there.
