Hey guys I'm addicted to this game and I really wanna raid. The problem now is that when I go on a raid frames skip badly, and bodies appear from one corner and two seconds later they are somewhere else. I beleive the problem is my video card but I'm not sure. Currently I'm also running at low settings , but I can also run high settings as long as im not in a raid. So maybe you guys can help. I was thinking of getting either a 9800 Pro, 6600GT, or 6800 depending on what I feel like spending.
My system specs are:
AMD 2400 @ 2800
1 Gig of ram, 1 is PC2300 the other is PC3200 I'm running it at 166
Leadtek 5900XT.
80gb WD w/8 mb buffer
80gb IBM Deskstar w/2mb buffer
Asus A7N8X-Deluxe
So you guys think a video card would give me better frame rates? Or should I upgrade the CPU and mobo. Thanks!
AMD 2400 @ 2800
Leadtek 5900XT.
Asus A7N8X-Deluxe
