what to put parts on while exchanging cases
This weekend I'm ordering a new case and a modular psu and im swapping out the main components(mobo/cpu, vid card, hdd, etc.) and putting them into the new case with the new psu. Im wondering what i should put the parts on while they are out of the case, seeing that i dont have any anti-static bags or anything like that. Any common household suggestions?
I second that, while suggesting if you still have the motherboard box, you can put your motherboard on that, with the plug-in edge barely hanging off of the edge of the box, so that when you plug in your add-on cards, the end of the bracket hangs off the edge
Ok thanks, I was thinking of the cardbox box but wasnt sure so I figured I'd ask just to be safe. Oh and another thing, would I be able to put 2 different size fans on a single channel on a fan controller? In my case, a 90mm and 120mm? I'm not sure if the different voltages or watts for each one will make a difference or not since they will be spliced. Thanks again.
Just make sure the fans don't pull more watts than one channel on the controller is rated for. Most controllers should be able to run two fans on one channel.
Ok thanks. I knew about the watts; both fans together are only like 2 watts and the channels can handle up to 18. I just wasnt sure about the size difference. Thanks again guys.
