Jun 26, 2004 #1 R rusty Limp Gawd Joined Nov 9, 2002 Messages 380 Im thinking of going sff for college, which model should i go with? i plan on getting an amd 64 3000+ and 1gb corsair xms pc3200
Jun 26, 2004 #2 M MrE 2[H]4U Joined Jun 19, 2004 Messages 2,408 Whats an SN85gl? Not familiar with that. Shuttle makes an SN85G4 and an SK83G for AMD 64. Regards, -E
Jun 26, 2004 #4 R rusty Limp Gawd Joined Nov 9, 2002 Messages 380 http://us.shuttle.com/specs_access.asp?pro_id=426, my bad, i forgot the 4, sn85g4L
Jun 27, 2004 #5 M MrE 2[H]4U Joined Jun 19, 2004 Messages 2,408 Its the same unit as the G4 minus the card reader on the front of the case. Can't go wrong with either setup. The Corsair memory is a good choice on this box as it tends to be a bit picky with anything other than Corsair or Kingston HyperX. Regards, -E
Jun 27, 2004 #6 A agentzero9 2[H]4U Joined Apr 27, 2002 Messages 2,799 Looks like there is no V2 for the L version though. That's a deal breaker.
Jun 27, 2004 #7 M Moses n00b Joined Jun 9, 2004 Messages 47 Agreed! I'd go with the SN85G4V2...make sure its the 2nd revision...its way better with the cooling, much quieter as well!
