Wondering if I can get some advice
I am toying with the idea of using the following setup;
I currently have Dish network which I split out to sling box & reciever; from reciever to my CRT HDTV. What I would like to accomplish is using my HTPC (currently used for Streaming of ripped material) is have the slingbox passhtourgh connect to the HTPC so I can watch SDTV (don't have HDTV reciever yet) on the HTPC (hope you are still with me).
What I am wondering is what will my results be, if I hook up a PCI/USB tuner to the HTPC which is displaying 1080i, given that SD is only 480i will a tuner upscale (if so which one?) or will the picture look really crappy?
Thanks in advance for any & all advice
