What to do......
HyperTension
Ok gents, I need some advice / opinions.
I currently have an ES6600 from another forum member here that does 3.6 with good aircooling. However, I don't know wether or not to get a new motherboard (680i), and memory (4gig set), or just add a 2gig set for a total of 3gig and wait to see what Barcelona does, and then make the move.
(Hopefully by then, some decent drivers will be out for the 8800 / R600)
Thanks Gents,
Chris
Unless you are going to be using a 64bit os I wouldn't get 4mb. Even with 4mb it is debateable how much it will help. The types of programs and your computer usage make a big difference.
I'm probably going to stick with XP for time being, hence the thought for going for 3GB, however, If it's recommended to me to go with a new setup, I'll go 64bit Vista to fully support 4GB.
Need more opinions.. :)
Its your money so the decision is all yours..... But since you have the cpu already, Id go for it especially since you have to buy more rams anyways.....All you need is the mobo anyways right? I was thinking of getting the 64bit Vista but I went for the 32bit instead, Still not really usefull yet so its not worth teh chance of getting a headache, called MS and to upgrade later to 64bit is only $15.....
Yeah, if u love the smell of fresh motherboard anti-static plastic then get a new mobo but only if the main reason is just to have the newest fancy thing, other wise wait until something really new and cool (cpu wise) comes out before making your move and DEFINETLY dont bother with 3gig. Wait and then get 4gig + 64bit
