What to do with an old Intel I7 CPU?
Discussion in 'Intel Processors' started by erehwon6811, Oct 4, 2017.
  1. erehwon6811
    erehwon6811 Limp Gawd
    493
    Aug 5, 2004
    I recently picked up a pair of older motherboards from a garage sale. Only one had a CPU. It's an Intel Core i7 CPU 920 running at 2.67GHz. It's a socket 1366 processor. How much use could I get from this? I was thinking of using it as a server and encoding movies with it.
    The second board is an Asus P6T6 WS Revolution and it is socket 1366 motherboard. I've seen this board sell well on ebay. I'm thinking about picking up a cheap xeon cpu to throw in to test the board. The socket 1366 I7 processors were more than I wanted to spend for a test cpu. By the way, would a xeon require ecc ram or could it work with regular ram?
  2. LigTasm
    LigTasm [H]ardness Supreme
    4,977
    Jul 29, 2011
    Why don't you just put the 920 in the second board to test it?
  3. erehwon6811
    493
    Aug 5, 2004
    I guess I could do that. A part of me was being lazy and not wanting to deal with pulling the motherboard. The I7 came installed with this massive Prolimatech Megahalems cooler. I'd have to pull the motherboard to get the backplate off.
  4. Grebuloner
    Grebuloner Gawd
    647
    Jul 31, 2009
    Seeing as how you just acquired a 2009/2010 setup with a cooler of the same vintage, may I strongly recommend you reapply the thermal paste anyway. No telling how old & crunchy it is.
    Also, the 920 and Gulftown Xeons are still very viable Boinc/Folding crunchers if you're into distributed computing at all. (And Xeons do run on regular ram)
  5. Master_shake_
    Master_shake_ [H]ardForum Junkie
    9,445
    Apr 9, 2012
  6. LigTasm
    4,977
    Jul 29, 2011
    Oh ok it was a full rig, I was thinking you just got the boards and CPU. The 6 core xeons can be had for cheap, definitely make a decent rig if a little power hungry.
  7. TheRealDarkphoX
    TheRealDarkphoX n00b
    29
    Mar 2, 2016
    Please don't laugh at me, but I'm still running an I7 920 in my primary rig. I also have one running a home server, and I do a decent amount of video encoding with it. Because of my preferred settings, it does go pretty slowly. I'm talking 12 hrs for something like turning a bluray to an mkv. However, your settings and use cases could end up taking much less time. IDK.
    I'm looking at upgrading to an 8700K later this year and hope to see some big jumps in encoding and gaming, but if you want to run a home server and do some encoding, I think you'll be content with it.
  8. erehwon6811
    493
    Aug 5, 2004
    It wasn't a full rig. Both boards were loose in a box, one board with cpu and heatsink attached and the other board only. It was a gamble for $10, but one worked. I have the one set up in the only case of mine that would fit that cooler. I wasn't really wanting to pull the motherboard to test the other one.
    I noticed the xeons were pretty cheap. I was looking at just getting one of those to test the second board and throw it on ebay if it works. If it's working, that board could sell for $150. I need to check what the other board is selling for.
  9. jmilcher
    jmilcher [H]ardness Supreme
    4,306
    Feb 3, 2008
    The 920 goes for as little as $20 now adays. But the motherboard is worth some money. I'd personally throw a used Xeon on it.
  10. erehwon6811
    493
    Aug 5, 2004
    I'll see about getting a cheap xeon for the asus and ebay it. I think I'll sell the I7 on ebay as well. I don't really need it as a server. With what those boards are selling for, that will add nicely to my new PC fund.
  11. txsizzler
    txsizzler [H]ard|Gawd
    1,472
    Feb 17, 2012
    If the mobos support it, stick a 5650/5660/5670 Xeon 6 core on there, and OC that motha to at least 4ghz. They hold up well with today's newer offerings, and from what I have seen, do not really pose a bottleneck to the latest gpus.
  12. legcramp
    legcramp [H]ardForum Junkie
    10,822
    Aug 16, 2004
    How much could I get for my system in sig?
    X5650
    Gigabyte X58 motherboard
    12gb triple channel memory
  13. erehwon6811
    493
    Aug 5, 2004
    That could be a project for me. I haven't OC any of my processors. I'm just tempted to sell the boards, since it looks like I could get $200 to $300 for both. That would add nicely to the $1500 I have saved up ebaying stuff for a new PC.
    txsizzler likes this.
  14. H2R2P2
    H2R2P2 Limp Gawd
    407
    Jun 18, 2006
    I have a 920 based systems and even a couple Asus P6T6 WS Revolution's with Intel 950 CPU's in them. They are viable systems especially if you throw an SSD in them. And you dont need to use ECC with a Xeon.
