kevineugenius
- Dec 9, 2006
During troubleshooting on my latest build, I wanted to eliminate all variables so while in strip-down mode I pulled a brand new PSU out of my closet that I've been sitting on (for troubleshooting needs) for a couple years at least and plugged it in with some difficulty, but not too much. Components at that time were:
Gigabyte Z68X-UD4-B3
2600k stock
1x 4gb 1333 G.Skill Ripjaws
1x 10k rpm SATA
1x XFX 6870
CM Hyper 520
2 case fans plugged into motherboard
According to my calculations, it should draw 515w under heavy load, so my PoS Sigma 535w PSU should run it when it's doing absolutely nothing... right? It wouldn't even power on. Just kinda spun the fans half a rotation then powered back off.
So, is that PSU defective or just a pile of crap? I think I got it in a combo or something back in the day. Should be this beast http://www.newegg.com/Product/Product.aspx?Item=N82E16817226003
Either way, I'm thinking of just turning it into spare wires and wire ends for if I ever need to splice up an adapter in the future...
2600k stock
1x 10k rpm SATA
1x XFX 6870
CM Hyper 520
