So i was cleaning out the store yesterday and came across my old silver Chieftec
I was like YeaY....cos i switched from that Chieftec to a Wavemaster cos i had to bring my rig overseas...and now that im back for good, i need a bigger case...Was originally planning on getting the CM Stacker 830...But since i found this
I just basically wanted a big ass case without all the bell's and whistles...Over here, im short of choice and the Stacker was as close as i could get..
However, I have the cash to get the Stacker...so i thought before I splurge on it, I thought i might do something to my Chieftec...So just wondering if anyone here has a similar casing who has done anything to it ? Its completely stock right now...and completely empty...
Ill post pics of it later...Basically i wanna try and make it as functional as possible...and if i screw up...i can just go meh...and get teh Stacker
The only aesthetic change i might to do it, is to add a windowed side panel and some lighting...tahts it...I wanna make it as air cool as possible..so suggestions for where to make 120mm, 80mm etc holes and plonk in fans ins appreciated...
