PWMK2 said:You have almost exactly the same system as me (well, the CPU / video card, anyway).
I would say... get more ram. I'm about to do that, actually. Your CPU and video card are fine. Since you have a s478 CPU, I guess you're on an AGP system. If that's the case, you should know that you are the owner of the fastest card to ever come out on AGP (except for those European Gainward ones), so there won't be any upgrade options there.
Getting a larger HDD definitely won't hurt either...
Shmuckety said:Are there any OC options on the board? If so OC the processor, get 2GB of faster ram and that should be good for a little while and cost you like $200 or less.
B. W. said:I'd save it until you know exactly what you want to buy.
Why waste is now if you don't need to?
True but I can counter that argument by saying: If I'm going to buy a G7, G15, Plextor 716-AL slot loading dvd drive that can fit in any pc, why buy it in a year when I can buy it now and when I build my new pc, I can unplug it from my old one and put it in my new one. Same thing with the zalman CNPS9500 led and VF900 which I am planning to buy. Can u give me a reason not to buy them?jnick said:Exactly.
you'll be paying more for it now, i always have the itching feeling to spend my money everytime i got some, but it will always help if hold on to it for a little bit longer and you will be able to get a much better system in 07 when u build that one, and those parts will be cheaper too and how do u know that they might just become outdated by then cuz all the new stuff is coming out Q2 this year so i would wait, im saving up right now so i can get a ill m2 system when they come out in Q2 this year, im ub3r hyped about that new system, im scratching up as much money as i can for it!!!alik4041 said:True but I can counter that argument by saying: If I'm going to buy a G7, G15, Plextor 716-AL slot loading dvd drive that can fit in any pc, why buy it in a year when I can buy it now and when I build my new pc, I can unplug it from my old one and put it in my new one. Same thing with the zalman CNPS9500 led and VF900 which I am planning to buy. Can u give me a reason not to buy them?
In a year more like like a few months from what i have read. he's better off saving the cash he has or build a low budget 64bit rig around the 939 socket.Mayhs said:whatever you buy now will be obselete in a year becuase youll be wanting the better cooler/mouse/soundcard/accessory for your shiny new comp...just save it...or invest it make some more money then spend twice as much on your new comp![]()
alik4041 said:So you're saying it's wrong to buy a G7 if I'm going to buy it for my new pc any way? I dont find the logic in that. The price will go down at most $5. I can get the G7 black for $65 and the G15 keyboard for $67 right now. So whats the point of waiting?
It really depends. If you can find a real use for spending that much on a mouse or drive, then go for it. But if you can do without it for the moment, what's wrong with saving your money and waiting for newer technology to hit the market?alik4041 said:So you're saying it's wrong to buy a G7 if I'm going to buy it for my new pc any way? I dont find the logic in that. The price will go down at most $5. I can get the G7 black for $65 and the G15 keyboard for $67 right now. So whats the point of waiting?
alik4041 said:sorry. I just dont see how the G7 can be outdone. It's not like the GPU age where every 2 months something new is coming out.
i'm going to bestbuy right now to buy the lowest agp card I could find and test it on my mobo then return it. If it works that means its the card, if not then its the mobo.Mayhs said:well i guess u thought the same about the earlier versions of the mouse...if you use your computer now buy it and be satisfied![]()
sry to hear about the card im sure ati will just send you back another one..they dont have time to look for ocing etc
