ValeX said:attach them all to a couple wires and lick it
Where did you find a 300-volt B+ battery? The highest voltage I've seen is 90, and 67.5 was more common.Frank4d said:I licked a 300 volt battery once to see if it was good (they used to be called "B" batteries). WHOA! various psychodelic colors were seen before I almost blacked out.
98EXL said:those LED Throwies are cool...how long do they last? In terms of hours?
Fenris_Ulf said:Make some super multi-LED throwies.
http://www.instructables.com/ex/i/7DBB34EAEDFF1028A1FC001143E7E506/?ALLSTEPS
http://graffitiresearchlab.com/?page_id=6
No capacitor would give you the right voltage. Capacitors block direct current.lozaning said:folks i think we have a winner
any one know what kinda caps i would need to get to get the right voltage for leds?
CR3032 batteries are typically rated at 500 mAh, which means we can expect them to drive a 15 mA LED for about 33 hours. mAh rating for batteries isn't very standardized, so the empirical result will depend on where the manufacturer draws the voltage drop cutoff line and the minimum forward voltage of the LED you've chosen.98EXL said:those LED Throwies are cool...how long do they last? In terms of hours?
mikeblas said:No capacitor would give you the right voltage. Capacitors block direct current.
A resistor is a useful device for limiting current. Divide 9 by the forward current shown on your LED's data sheet. For a typical LED, 15 mA is a safe forward current. 9 / 0.015 == 600 ohms.
You need to use a quarter-watt resistor; an eighth-watt resistor is too small.
A more interesting challenge is figuring out how big your magnet will need to be in order to make the throwie stick with the comparatively heavy 9v battery attached to it.
I'm not sure I understand your question. What you need has already been provided; others have linked to instructions, and I've told you how to do the math to get the correct resistor value. What's missing?lozaning said:as you can eassily tell i not that good when it comes to this kinda thing, so a link to what i would need would be very apreciated
mikeblas said:I'm not sure I understand your question. What you need has already been provided; others have linked to instructions, and I've told you how to do the math to get the correct resistor value. What's missing?
I don't know; it depends on your LED. Some of the lower values should work, but you only get a few because you're buying an assortment and not a bunch of the same value.lozaning said:i guess what i am asking is will these work?
Battery + ----resistor----\
LED
Battery - ----------------/
well i just wanted some help.mikeblas said:(Did you do the math, or are you expecting me to do it for you?) .
Do you think I've not helped you enough?lozaning said:well i just wanted some help.
Had you done the math, you would've known why.lozaning said:i baught [sic] the 10megohm resistors and those dont seam [sic] to work,
mikeblas said:Do you think I've not helped you enough?
Amazingly enough, it's actually the reverse. What happens is that as the battery gets discharged, its voltage decreases, but the LEDs drop the same amount of voltage. Which means that less voltage is dropped across the resistors, and so (I=V/R) the current decreases. And as the current decreases, the battery discharges more slowly. The LEDs will be dimmer, but they'll still be lit for far longer than 15 hours.Frank4d said:A car battery rated 200 AH (amp hours) should power 600 LEDs for 200AH/12.6A = 15.87 hours. Actually less since the battery voltage will decrease over time.
Skaterpunk said:so 600 blue LEDs. 200 strands of 3 each with a resistor would work on a car battery?
Stuey83 said:According to the other posts, yes, this should theoretically work. However, it's not adviseable.
Let's say you make a mistake when you connect one of the LEDs (reverse it perhaps), or everything is wired correctly and LED dies. You then have a string of 200 LEDs which won't light up, meaning you'll have to use a multimeter to check for continuitiy between each and every one in order to find the dead component.
Fenris_Ulf said:Actually, 3 LEDs wouldn't light up, the 200 strings are in parallell.
Stuey83 said:LOL, for some reason I read and reread the posts and still thought that they were referring to 3 strings of 200 LEDs. I kept thinking that noway it could even work at all, but I figured maybe you guys knew something that I didn't. LoL, THAT'll teach me to post after a sleepless night.
I would make 200 strings of 3 LEDs, each with a resistor.
