leSLIe
Fisting is Too Mainstream for Me
- Oct 18, 2004
I recently had some problems with my PC's power cord, and the PC shutdown, well i copy the backup files and start the SMP clients again, first "FaH SMP2" and i got "Folding@Home Core Shutdown: FILE_IO_ERROR",
weird thing here is that all the cores were at 100% !! and there is apparently nothing going on, so i waited a couple of minutes and start the second client "FaH SMP1" and there was this message "Folding@Home Core Shutdown: FILE_IO_ERROR" which was the same as with the other client, except this time, it moved on, and start over.
to summarize, i restarted my SMP clients after a PC shutdown, with the backup files, one client got to continue and the other one is stuck. now what do i have to do to make the non working client to start folding again?
pic of the task manager
i'm getting weary of this ... should i start using a VM?
Code:
Note: Please read the license agreement (fah.exe -license). Further
use of this software requires that you have read and accepted this agreement.
If you see this twice, MPI is working
4 cores detected
No directory settings found in registry. Using current directory...
--- Opening Log file [May 2 14:45:33]
# SMP Client ##################################################################
Folding@Home Client Version 5.91beta6
http://folding.stanford.edu
Launch directory: D:\Folding@Home\FoldSMP2
Executable: D:\Folding@Home\FoldSMP2\fah.exe
Arguments: -advmethods -forceasm -verbosity 9
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[14:45:33] - Ask before connecting: No
[14:45:33] - User name: leSLIe (Team 33)
[14:45:33] - User ID: 2A15A7363A356C29
[14:45:33] - Machine ID: 2
[14:45:33]
[14:45:33] Loaded queue successfully.
[14:45:33] - Preparing to get new work unit...
[14:45:33] - Autosending finished units...
[14:45:33] Trying to send all finished work units
[14:45:33] + No unsent completed units remaining.
[14:45:33] - Autosend completed
[14:45:33] + Attempting to get work packet
[14:45:33] - Will indicate memory of 1024 MB
[14:45:33] - Connecting to assignment server
[14:45:33] Connecting to http://assign.stanford.edu:8080/
[14:45:34] Posted data.
[14:45:34] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[14:45:34] + News From Folding@Home: Welcome to Folding@Home
[14:45:34] Loaded queue successfully.
[14:45:34] Connecting to http://171.64.65.63:8080/
[14:45:36] Posted data.
[14:45:36] Initial: 0000; - Receiving payload (expected size: 608878)
[14:45:39] - Downloaded at ~198 kB/s
[14:45:39] - Averaged speed for that direction ~189 kB/s
[14:45:39] + Received work.
[14:45:39] + Closed connections
[14:45:39]
[14:45:39] + Processing work unit
[14:45:39] Core required: FahCore_a1.exe
[14:45:39] Core found.
[14:45:39] Working on Unit 02 [May 2 14:45:39]
[14:45:39] + Working ...
[14:45:39] - Calling 'mpiexec -channel auto -np 4 FahCore_a1.exe -dir work/ -suf
fix 02 -priority 96 -checkpoint 15 -forceasm -verbose -lifeline 2156 -version 59
1'
[14:45:39]
[14:45:39] *------------------------------*
[14:45:39] Folding@Home Gromacs SMP Core
[14:45:39] Version 1.74 (March 10, 2007)
[14:45:39]
[14:45:39] Preparing to commence simulation
[14:45:39] - Ensuring status. Please wait.
[14:45:40] - Starting from initial work packet
[14:45:40]
[14:45:40] Project: 3062 (Run 4, Clone 15, Gen 97)
[14:45:40]
[14:45:40] Assembly optimizations on if available.
[14:45:40] Entering M.D.
[14:45:57] on if available.
[14:45:57] Entering M.D.
[14:46:03] Couldn't open Go file
[14:46:03]
[14:46:03] Folding@home Core Shutdown: FILE_IO_ERROR
[14:46:03]
Code:
4 cores detected
--- Opening Log file [May 2 14:50:22]
Launch directory: D:\Folding@Home\FoldSMP1
Executable: D:\Folding@Home\FoldSMP1\fah.exe
Warning:
use of the flag.
[14:50:22] - Ask before connecting: No
[14:50:22] - User name: leSLIe (Team 33)
[14:50:22] - User ID: 2A15A7363A356C29
[14:50:22] - Machine ID: 1
[14:50:22]
[14:50:22] Loaded queue successfully.
[14:50:22] - Preparing to get new work unit...
[14:50:22] - Autosending finished units...
[14:50:22] Trying to send all finished work units
[14:50:22] + No unsent completed units remaining.
[14:50:22] - Autosend completed
[14:50:22] + Attempting to get work packet
[14:50:22] - Will indicate memory of 1024 MB
[14:50:22] - Connecting to assignment server
[14:50:22] Connecting to http://assign.stanford.edu:8080/
[14:50:22] Posted data.
[14:50:22] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[14:50:22] + News From Folding@Home: Welcome to Folding@Home
[14:50:23] Loaded queue successfully.
[14:50:23] Connecting to http://171.64.65.63:8080/
[14:50:24] Posted data.
[14:50:24] Initial: 0000; - Receiving payload (expected size: 608255)
[14:50:27] - Downloaded at ~197 kB/s
[14:50:27] - Averaged speed for that direction ~114 kB/s
[14:50:27] + Received work.
[14:50:27] + Closed connections
[14:50:27]
[14:50:27] + Processing work unit
[14:50:27] Core required: FahCore_a1.exe
[14:50:27] Core found.
[14:50:27] Working on Unit 02 [May 2 14:50:27]
[14:50:27] + Working ...
[14:50:27] - Calling 'mpiexec -channel auto -np 4 FahCore_a1.exe -dir work/ -suf
fix 02 -priority 96 -checkpoint 15 -forceasm -verbose -lifeline 3780 -version 59
1'
[14:50:28]
[14:50:28] *------------------------------*
[14:50:28] Folding@Home Gromacs SMP Core
[14:50:28] Version 1.74 (March 10, 2007)
[14:50:28]
[14:50:28] Preparing to commence simulation
[14:50:28] - Ensuring status. Please wait.
[14:50:45] - Assembly optimizations manually forced on.
[14:50:45] - Not checking prior termination.
[14:50:45] - Expanded 607743 -> 3260637 (decompressed 536.5 percent)
[14:50:45] - Starting from initial work packet
[14:50:45]
[14:50:45] Project: 3062 (Run 5, Clone 157, Gen 9)
[14:50:45]
[14:50:45] Assembly optimizations on if available.
[14:50:45] Entering M.D.
[14:50:50] work thread failure
[14:50:50] - Shutting down core
[14:50:50]
[14:50:50] Folding@home Core Shutdown: FILE_IO_ERROR
[14:50:50] Finalizing output
[14:50:56] CoreStatus = 7B (123)
[14:50:56] Client-core communications error: ERROR 0x7b
[14:50:56] Deleting current work unit & continuing...
[14:53:16] - Warning: Could not delete all work unit files (2): Core returned in
valid code
[14:53:16] Trying to send all finished work units
[14:53:16] + No unsent completed units remaining.
[14:53:16] - Preparing to get new work unit...
[14:53:16] + Attempting to get work packet
[14:53:16] - Will indicate memory of 1024 MB
[14:53:16] - Connecting to assignment server
[14:53:16] Connecting to http://assign.stanford.edu:8080/
[14:53:16] Posted data.
[14:53:16] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[14:53:16] + News From Folding@Home: Welcome to Folding@Home
[14:53:16] Loaded queue successfully.
[14:53:16] Connecting to http://171.64.65.64:8080/
[14:53:20] Posted data.
[14:53:20] Initial: 0000; - Receiving payload (expected size: 2435236)
[14:53:32] - Downloaded at ~198 kB/s
[14:53:32] - Averaged speed for that direction ~142 kB/s
[14:53:32] + Received work.
[14:53:32] + Closed connections
[14:53:37]
[14:53:37] + Processing work unit
[14:53:37] Core required: FahCore_a1.exe
[14:53:37] Core found.
[14:53:37] Working on Unit 03 [May 2 14:53:37]
[14:53:37] + Working ...
[14:53:37] - Calling 'mpiexec -channel auto -np 4 FahCore_a1.exe -dir work/ -suf
fix 03 -priority 96 -checkpoint 15 -forceasm -verbose -lifeline 3780 -version 59
1'
[14:53:37]
[14:53:37] *------------------------------*
[14:53:37] Folding@Home Gromacs SMP Core
[14:53:37] Version 1.74 (March 10, 2007)
[14:53:37]
[14:53:37] Preparing to commence simulation
[14:53:37] - Ensuring status. Please wait.
[14:53:54] - Assembly optimizations manually forced on.
[14:53:54] - Not checking prior termination.
[14:53:58] - Expanded 2434724 -> 12901369 (decompressed 529.8 percent)
[14:53:58] - Starting from initial work packet
[14:53:58]
[14:53:58] Project: 2653 (Run 14, Clone 12, Gen 51)
[14:53:58]
[14:53:58] Assembly optimizations on if available.
[14:53:58] Entering M.D.
[14:54:06] Rejecting checkpoint
[14:54:07] Protein: Protein in POPCExtra SSE boost OK.
[14:54:07]
[14:54:08] Extra SSE boost OK.
[14:54:09] Writing local files
[14:54:09] Completed 0 out of 500000 steps (0 percent)
