hey all, its nice to visit back here after a while, lovely forum, lots of info and advice to make comparisons with!
ok i'll try and keep this short..
i've got a good old 9700 np at 9700 pro speeds, but 30-40fps in cs source just dosent cut it anymore, i'd like ideally 60-70++
Basically i've been looking at 9800 pro's for the past 2-3 days and trying to decide on which one to get for modding to a 9800XT
i think i'll just go with a 128 meg one, as this should be sufficient for CS:Source.. well i presume so
i'm in the UK, and am currently looking for one, hoping that I can get an R360 core one, basically, i'd like you guys input as to which one to go for, i know its probably random, but if anyone has any extra info or suggestions as to which one i should buy, then please do!
I would love to newegg it, but unfortunatly with me being in the UK, newegg does not have a UK site or anything.
the choices are basically here:
1) http://www.overclockers.co.uk/acatalog/9700_to_9800_Series.html - the top two, here is a connect3d and sapphire cards, both look similar, and both look like they could potentially have r360 cores, though i couldnt say for certain as the shop dosent say how new theyre stock came in
2) http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=55198 - My friend got this card, i told him what to do to flash it, and he flashed it today, and successfully, i think his was a r360 core, and he bought it 12 days ago, so if i ordered this card, i may be in for a chance of having the same stock as him and getting an r360, though I cant purchase ramsinks aswell from this site, which is why i'm thinking about going with option 1..
3) http://www.aria.co.uk/ProductInfoComm.asp?ID=15264 - the 'play it safe' option, this card is condiserably more expencive, but would guarantee a decent core/core speed card, then again it does seem that this card is pretty similar to the 9800 pro if i bios modded the 9800 (provided i got an r360 core), so i really dont think i should go for this one.. but i would really feel better if i got a good 'bang for my buck' deal
What do you guys think would be my best chance with getting an r360 core? I know its more than likely just luck of the draw.. but hey.. maybe someone knows something i dont.
Or, if anyone knows any other UK sites, that could potentially have a good chance of r360 cored 9800 pro's, then please fill me in.. i'm more than likely going to get one tomorrow, as i've wasted so much time contemplaiting over which one to get, thanks!
