Shadow0599
- Feb 23, 2015
This past weekend I turned on my computer and the sound that came from it sounded like that of a helicopter, and it was very loud and annoying. So, I opened up my case, only to find that the fan (roughly 4.5" in diameter) on my CPU liquid cooling was cracked down the middle. Now, the fins of the fan are all still attached, but only the center of the fan is cracked, which has one crack down the middle of that center part and one radial crack coming off of that, forming a t-shape of cracks.
I have an AMD Fx-6300 CPU which I bought from ibuypower.com last year, and the liquid cooling came with it. Also, I really want to upgrade my CPU to an Fx-8530, but I understand that with that I either have to buy a new liquid cooling system, or just use my old one (which is cracked). Also, I have an Asus M5A97 R2.0 motherboard.
So, I'm asking if I can replace only the fan in my liquid cooling system? OR, if not, which liquid cooling cooling system is the best for my AMD CPU, but also isn't too expensive, considering I'm still saving money for my CPU upgrade?
Thanks!
Thanks!
