2Fresh said:I am on a DFi now with a Barton2500@2.76. I have the setup for a 64 AMD ot a P4 setup. I dont want to spend an arm and a leg, but what would be the best bang for the buck out of these?...along with a mobo.
Shapeshifter said:well you could try and find the "ultimate" XP mobile chip.
Those low watt ones (2400+) I belive are doing very well.
You could try and beat the record. which is 3.5ghz on a mobile (stable to I belive, few people have done it, one guy used LN2 thou) totally kills anything in benchs. Wish I still had the link to it :/
Warriorprophet said:nForce3 250gb ala http://www.newegg.com/app/ViewProductDesc.asp?description=13-130-457&depa=1
and 754 512k ala http://www.newegg.com/app/searchPro...t=Go&description=754+512k&Range=1&Order=price
And they even have some mobile A64 if you wanna pioneer O/Cing those for us.
Peace.
P.S.
Razer Viper ETA 06/09 here too http://www.newegg.com/app/viewProductDesc.asp?description=26-153-101&depa=1
Genocidal said:Socket 940 is out, and has been for awhile. Do you mean 939?
2Fresh said:How does that mobo oc, or the cpu's that go along with it?
How about the 940 mobo?
oqvist said:There isn´t really a point getting the low watt if you have phase change. You will hit the limits of the chip either way. And that for most mobiles seem to be 2,7... I don´t know how many phase change users hit the roof at 2,7...
kronchev said:get a 939 board, 754's are being phased out
