After refilling my watersetup I got very bad temps. Idle temps of like 44 degrees. I had some airbubbles going through my system back and fourth but non in the waterblock it seemed. Let it run continously for 2 days and the temps went down to 42 which still was way more than normal even after a refill. All I did at that time was using the internet.
So then I try some gaming and then check my temps and they get down to 35??? Are my mainboard temp probe going nuts? 35 is quite normal and very similar to what I got before. And I still got bubbles going around so don´t know what have changed?
My system temps went down like 10 degrees also.I have refilled it like 7 times now and never got this kind of result really before. Generally the cooling performance didn´t enhance after the bleeding process with more than perhaps 1 degree.
