The last 7 or so posts have been extremely helpful and completely solved my problem.
If you want a solution to your problem here it is: Switch the OS to something else. You probably didn't like that answer.
As of now, that is one of two solutions. The other being disable updates in win10 after reinstalling again. However, I may just say screw it and use this as an excuse to upgrade.
Upgrade to what? You'll have to ditch Microsoft to upgrade
You'll probably be able to skip the problems by reinstalling and setting the updates to 'metered connection'. But then your windows will be even more vulnerable than it is with updates. If I were you I'd ditch Windows entirely for non-gaming purposes and start learning an alternative OS like OSX or linux.
Vulnerability is relative to the weakest link. I don't go to sites I shouldn't or run exe's I shouldn't. I'm perfectly happy running windows 10 aside from this issue. Also, certain video capture software I use does not work on any other platform. Therefore going from that software into an NLE is much easier without having to restart and switch OSes.
care to elaborate? I have yet to have any post update issue with any of our usersYou're not the only one to experience a hosed OS install as a result of a Windows update, I deal with them daily.
Yes, oh, yes, B00nie, you're so right, I switched to Linux and instantly had an orgasm. It's everything you said it was. Rainbows, Unicorn tears, perfection in every distro.
Yes, we know how perfect it is. Yes, we know it's better. You've done your job of informing everyone in these forums how excellent it is. Your job is over now. But, we're still going to use Windows. Bummer huh?
Too bad for you essentially. If you can't evolve you suffer and die.
little update. I clean installed last week after all of this shit, been working fine up until now. It installed updates last night/this morning, booted up fine. Then I played a game and browsed the web for a bit. Shut it down and now when I go to turn it on, SAME FUCKING DEAL. It freezes the second it goes to the SSD. POSTs fine but soon as it goes to boot windows it freezes before the logo right after numlock comes on. Fucking beautiful!
EDIT:
looks like other people started having the same issue a few days after I made this thread:
https://forums.lenovo.com/t5/ThinkS...nkstation-Won-t-Boot-Postcode-0d/td-p/3480429
So it appears to be a forced Intel driver update that's causing the issue?
I've been in the IT world a long time and I've seen new drivers fuck up working systems quite often.
I get that MS wants to force the security and other OS updates, but forcing driver updates is a really bad idea.
I couldn't find evidence of it being an Intel thing. The update in question modifies the boot manager with a security update. I'm going to see if uninstalling the update allows the system to boot.>>what's weird is system restore to an earlier point doesn't fix it.
It's maybe restoring the registry but not the actual previous driver.
I wonder if there is a policy item to lock down driver installs to Admin only.
>>I reset secure boot and bingo, everything ran fine from that point on.
There ya go, that sounds promising.
I mentioned Safe Boot, but yes I meant Secure Boot.
I'm not a fan of Secure Boot either, seems to cause more problems than it claims to solve.
mnewxcv, what update did you identify as being the culprit?
I believe older BIOS versions for this machine (Lenovo branded) had a secure boot option. The latest version and one before though do not. CSM, UEFI, and quick boot options are there. I am wondering if secure boot was just programmed into one of those options. I will try to roll back my BIOS to one that has the option tonight. Otherwise, I guess I have no option but to put the drive in my laptop, back it up, and start from scratch with a clean install. LAME.
EDIT: upon looking for an older BIOS, I found that Lenovo released a BIOS update yesterday with "undisclosed security updates". Doesn't mention anything about it fixing boot issues, and maybe just a coincidence it came out the day the problem I have started, but I will update and see if it fixes the problem.
