What temperature program for P4 processors?
goldznnz
i have tried core temp, but it does not work with my P4 processor
can you guys tell me what temperature program is best to use with P4 processors?
thank you all so much, i love this place :D
thanks guys, i tried it and its kind of hard to understand with it showing 3 temps and arrows with them, can someone elaborate on this?
(i'm dumb as an ox, sorry :D)
A blue arrow means the current temperature is below the desired temperature. The green check means the temperature is around the desired temperature. A flame means the temperature is around or greater than the warning temperature. These can be set in the configure menu.
Figuring out which temperature is which is a process of elimination thing. Run Prime, that'll give you your CPU temp quick. Your HD usually shows up as HD.
