What table should i get for my pc?
Hoshimoto
Yeah its not joke, i asking what table should i buy for PC (with CRT display), i live in really small town with lack of choice so probably i order custom made, this means it can be anything i want, someone have suggestion, link or maybe photo of table you have or wanna have.
This may sound stupid but i cant think of any good design.
I thinking to maybe take big corner table like this http://www.pc-desks.com/images/intelligent/10012.jpg, but want it to look as pc table and not like part of bedroom furniture and i hate pullout keybo@rd pane, though i can chane my mind about corner table if i find really decent and comfortable normal table.
What color will be good for Black PC?
EDIT: Don't hotlink images from someone else's site. - Lethal
Im a HUGE fan of the Ikea Jerker
Seriously though, its a good cheep but very robust desk, Im thinking about buying a second one to turn into an electronics workbench at a later date
Not bad though my crt wont fit there. I feel its going to be very huge table i need since my crt is 17" length and i need 8.5"-10" for keyboard, if not more, damn crt, guess i will have to upgrade desk if i find money for LCD one day, it just goina be to huge.
Only way to lower space i see is to use pullout keyboard pane that i hate or monitor stand with such design so my huge keyboard can fit under it, or smaller keyboard or larger table doh.
Or of course i can get normal sized desk, but will have to use pullout keyboard pance untill i get LCD and then i can place keyb on top of desk.
Do you guys think drawer (with door) for case is bad for cooling?
Should i use open shelf or place case on floor?
Drawer with door is bad for cooling since all the hot air will stay in the enclosed space. If I were you, I'd keep it at least 1 foot away from the floor so that floor particles won't get in as easy.
