What speed DDR2 does a 1066 C2D need?
The question is in the title I guess! Been out of the loop for a while, I'm a bit confused by the DDR2 ratings. I used to work out bus speed for DDR by dividing by 16 ie PC3200/16 for a 200mhz bus, is DDR2 the same? 1066/4=266 x16= PC4200/4300?
1066/2 = 533, so DDR2-533 is the absolute minimum you would need. But no one in their right mind would use that. :D With DDR2-667 and DDR2-800 prices dropping like flies, no reason to get just DDR2-533.
Yeah, DDR2 533 is the bare minimum (double the base FSB speed of the CPU, that's the RAM speed you need for DDR2).
But seriously, DDR2 800 is the way to go now. That stuff is getting so cheap these days.
Yea, in theory it's the same.
However, DDR2 is less efficient than DDR, so getting a perfect match between FSB and memory (x2 for dualchannel) is not the ideal situation.
Benchmarks show that DDR2-667 or DDR2-800 give a bit more performance even when not overclocking (although latency also has something to do with it... low-latency 533 memory may be better than high-latency 667 etc...).
I'd recommend to get 667 or faster, and the lower the latency, the better.
I run DDR2-800 myself, at 4-4-4-12 timings, pretty good balance between latency and clockspeed, and it wasn't extremely expensive memory.
