what sound card?
Cuddy8616
well im looking to spend less than $100 and i want to use this for recording, and listening to music. i really want to hook up a recording studio through my computer, and am not too sure which route to take. thanks
cuddy
I tell you what. I just got the new X-Fi xtreme music card.....the "cheap" one....Ive been messin around with it for about two days....music is outstanding on this card....Ive heard stuff that I just never heard on my old Audigy card....IMO its worth the extra dough. :D
I second that!
Donnie27
So, what kind of latency ya getting? Is the jitter too bad?
Recording gear is different from gaming gear. Until somebody who does recording has given their opinion of the X-Fi, I'd avoid it like the plague for recording.
i really like the EMU 1212m, it seeems to have all of the inputs i would need. i just hope that it is professional quality...does anyone on this board use a sound card for recording and not just for gaming? if not where could i find someone to help me with this? thanks
cuddy
The 0404 and 1212 are fine recording cards. I haven't used them personally, but everyone I've heard from likes them.
i now want to upgrade into the $200-$350 price range for a new recording sound card. any opinions? thanks
cory
What do you have now? The 1212? There's kind of a hole in that price range, and if you've got the 1212 already you won't see much difference with that kind of budget.
If you've already got the 1212, do a few more gigs (if that's your bag) or save up some and try the Tascam FW1082. It's got motorized faders and other cool features, and it's a lot nicer to use real faders than software ones. At $600 new it's not cheap, and I'd certainly find some reviews before I bought it, but it looks like good stuff.
right now i have a $50 creative soundcard, and i want to get into the $300 range of soundcards. i will be using it to record. which one should i get? thanks
The Emu 1212. Was the first go-round of this not clear enough?
A 2nd for the 1212m, unless you extend your budget just a little and pick up an EMU 1820 for less than $400. It occupies only one PCI slot (1212 needs two) and comes with a very convenient I/O breakout box.
I have a bud who swears by it and after hearing some of his Demos, I'm hooked but I'd also take a 1212 for recording.
