Hey guys,
I'm wondering which motherboard I should buy. My main use is gaming and folding, so I want something I can squeeze the most speed out of my CPU with... so I can get more points.
Yes, I going to finally give in and go Intel after being a die-hard AMD guy for 6 years. CPU will be an e6550 I'm getting slightly used. Hoping to overclock to at least 3.2 but hopefully somewhere around 3.5. I should also mention I am using 2GB of Corsair PC6400 DDR2 cas 5, which probably doesn't overclock well. Anyway, enough blathering.
Want:
+++Power efficiency
++Stability
+++Performance
+Digital Optical/ or dig coax. output.
+Crossfire would be nice, but not necessary.
Possibilities:
Asus P5KC Downside: Expensive another link
MSI P35 Neo2-F Downside: no digital sound output.
Gigabyte GA-P35-DS3R No crossfire.
As you can see I'm looking at P35 chipset, which I've heard is really good. But I am very ignorant about all things intel. Okay you Intel gurus, elighten me please...
I'm also worried about motherboard cooling, since my 2 amd motherboards both had really hot northbridges.
Want:
+++Power efficiency
++Stability
+++Performance
Possibilities:
