Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'll likely get a Tripp-Lite or an APC when I order my new vid card. How do I determine what size I need? I have no mission-critical stuff on my machine, so it is simply to protect the components, not to allow shutdown/save and whatnot.
Thanks for that link, David. I had no idea it was on the site- I was shopping at stores instead. It won't take as much as I originally had imagined. My pocketbook thanks you It'll definitely be worth $100 to protect a $3000+ machine.
