One gamer to another .....get biggest meanest widescreen mudda u can afford.cslogical said:I'm considering getting the Dell 2007wfp or the ViewSonic VX2025wm. Maybe possibly a nice 19". Please help me decide. Oh I play alot of fps games. Thanks
sethk said:I wouldn't agree. It does depend on the sort of gaming you do.
First of all, the smaller monitors (19 and 20") are currently available with faster panels. This may change but chances are with the faster large panels will come the introduction of even faster smaller panels. Ghosting is pretty bad (in my opinion) on the Dell 2405 for example (which I have.)
Secondly, and more importantly, is the issue of viewing angle. With 24" panels at normal viewing distance, you cant see the whole screen all at once without moving your eyes and head - in FPS games (especially multiplayer games) you are more likely to miss some action taking place at the edges of the screen. For more casual gaming, I would agree 24" can be more immersive because some of the action is happening in your vision's periphery.
Third, the higher resolutions really push the limits of todays video cards, even SLI based setups when you turn the eye candy on.
So evaluate what's most important to you, and the answer will become clear. I don't think there is one right answer so don't just listen to what everyone says, consider your own needs carefully.
I did a bit of research when looking for a gaming monitor and decided on the 19 inch viewsonic vx922 I have now. I use it dual monitor with my old dell 1901fp (25ms reponse.. yuck). Read nothing but great reviews on it. Only problem people have with it is that sometimes if you try to view the monitor from a higher or lower angle... the screen can appear to have different brightness levels.cslogical said:What are some really good 19" lcd's?
