Haxor said:What size hole saw should i use for an 80mm fan?
I did not know that. I would have figured if someone working with wood would want a 3" hole in something that they would use a saw that would leave a 3" hole. Why would hardware manufacturers size them from th ID and not the OD? That doesn't make sence to me. But then again I think it's silly that a 2x4 isn't 2" x 4"MD_Willington said:1 in = 2.54 cm
80 millimeter = 3.15 in
3 inch hole saw...remember 3 in is the ID not the OD...so the hole will be slightlt over 3 inches due to the saws kerf...
Kerf = The width of a groove made by a cutting tool.
MD
redhalo said:I did not know that. I would have figured if someone working with wood would want a 3" hole in something that they would use a saw that would leave a 3" hole. Why would hardware manufacturers size them from th ID and not the OD? That doesn't make sence to me. But then again I think it's silly that a 2x4 isn't 2" x 4"
Qtip42 said:Didn't you answer yer own question?
