What should I upgrade?
rjop455
Before I by I wanted to check to see what you guys thought. I already have a graphics card and a cd drive, but everything else is new. Tell me what you think
Case-
RAIDMAX SMILODON ATX-612WBP Black SECC STEEL ATX Mid Tower Computer Case 500W Power Supply - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16811156062
Hard Drive-
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16822144701
Motherboard-
MSI K9N Neo-F Socket AM2 NVIDIA nForce 550 MCP ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16813130050
Ram-
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400 - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16820145590
Processor-
AMD Athlon 64 X2 5200+ Windsor 2.6GHz Socket AM2 Processor Model ADA5200CSBOX - Retail
http://www.newegg.com/product/Product.asp?item=N82E16819103759
The total for this is $792.97. If there is anything I can get that is better for the same or less let me know :). Thanks for your time!
Why not intel? It would be the better choice (link1/link2). In either case, I wouldnt trust that 500W Raidmax that comes with that case. Go for an XClio 450W or Corsair 520W if you got the cash. Is $800 your limit?
drop the power supply. Get something like a corsair HX 520. Raidmax psu's with cases are pretty damn bad.
Try an intel core2duo, it > amd.
