What should I upgrade to
Mujen
I currently have an nvidia 430 gt, but it's unable to keep a good frame rate with bf3, I was thinking of going with a 560 gtx, and with having a micro atx also a 600 watt power supply, I want to have a card that will fit nicely. Thanks in advance!
560 Ti 448 core or a 570 GTX would probably work. With a 600W supply you would also do a single 580GTX, although it's quite expensive. The real question is what resolution are you playing at and what settings are you trying to achieve? BF3 can be a card killer. Also how much clearance do you have in your case?
Yeah i was hoping to keep it in the 200 dollar range, I usually play at 1920x1080, on low. But I would like to go up to high or at least have 40-50 fps.
A 560ti is going to be the best performing card in the $200 range.
HardOCP IQ Review says it would outperform the AMD "equivalent" 6870.
If you can go up to get it, there's an XFX 6950 1GB for $219.99 after MIR (plus $7.87 shipping, comes with free Dirt 3 key). While it performs about the same as a 560ti in BF3, it is the more powerful card and you may notice it on other games.
Another option would be the 6870. I have this one ($149.99 after MIR, free ship, comes with Dirt 3 key), and in BF3 with everything on high (default), I know I have room to bump some things up to Ultra. The 6870 is about $50 cheaper than the 560ti and performs nearly as well as the 560ti in most games, though the gap is a bit larger in BF3.
as usual, nobody has asked what the rests of the OP's pc looks like.
Mujen, if you are not going to use a sig then always list ALL of your other specs when asking these type questions. and please list them in detail as saying 600 watt psu means very little.
Mujen, if you are not going to use a sig then always list all of your other specs when asking these type questions.
It is a video card thread, and it is well known how stressful BF3 is on cards. So far nothing has come forward to suggest there was any reason to ask about the rest of the system.
are you kidding me? he could have a Pentium D for all we know. all of the other specs always need to be listed when asking for upgrade advice. many a thread has gone on for pages only to find out a video card is not the only thing needed.
He mentioned the GPU he is using, then mentioned the game that broke it is BF3. Might he need other components? Perhaps, but if BF3 is the only thing breaking it, then highly unlikely. Would it be nice if he listed other things, sure. Is it absolutely necessary and should we villify everyone because he didn't? No.
he has a very low end card and we have NO IDEA what the rest of his specs are. those ALWAYS need to be known. he could have a 2500k system or an outdated cpu and 2gb of system ram for all we know.
Mujen, please post what the rest of your specs are so cannondale can relax and breath a little. Plus he does have a point that it helps to know the full system specs.
I apologize. I'm still fairly new to the website, Iput my specs onto my signature
ty and yes you have a decent setup. that cpu is a little gimped though and is really just an Athlon 2 X4. the lack of L3 cache will hold it back in some games.
and you still did not say what the exact model of psu that you have is. if your psu is a decent brand then yes a gtx560 will be a nice card for you.
