What should I get?
gentrinity
Im looking at HP notebooks and the prices are really great. The 17' inch models allow for RAID 0 with two 80GB 5400RPM HDs, and I dont know how much of an upgrade thats going to be over getting an aftermarket travelstar 7K100, please comment.
Raid 0 on a laptop? I would avoid that, and go for one 7200rpm drive for the boot drive. If you want more space, get a big slower drive in the 2nd slot. But that is just my feeling on the subject.
I think the correct answer to this question depends on your application needs. If you are looking for a laptop with a longer battery life, using two HDDs is a poor idea, since they are going to draw more power than the single 7.2k rpm drive.
However, if you application can be sped up significantly by using RAID-0, then there may be a good reason for using two drives.
All-in-all you haven't told us what you want to do with your Laptop aside from the "price is great", so commenting on this is pretty hard, don't you think?
Despite the increased shock tolerance of laptop drives, I'd still worry a lot about dropping it and destroying all your data. Unless you're using the machine for something that needs a high STR (video capture, audio capture, or database stuff), I'd recommend against raid 0.
While I kinda agree with unhappy I'll add to it. Raid 0 will give you a tiny preformance bump but at the cost of battery life and give more points for failure. If you get one have a good backup plan where the important data is backup off the system. If you are getting a 17 inch notebook I question how important battery life would be but it is something to consider.
