What should i do?
Status
Not open for further replies.
Marc113-
What should I do???????
strip it for skrews and pci blanks, turn the psu into a tester or make your own adapter/splitters... send me the cpu, ill pay shipping, i want to use old cpus as molding in my room
edit, use the case as scrap to modd with or work on your modding with the case, so you get the hang of using tools
Stop. Posting this. Okay?
This is the 3rd or 4th thread you've made about this. If they've gotten locked, THERE'S A REASON. This thread is SHENS, it's NOT funny, GO AWAY.
Buy a garbage can. They are cheap and make a convient place to store crap until it can be taken to the land fill. Throwing stuff out the window just looks bad.
pee on it then set it on fire to get rid of all the evil inside of it :D
if you could put it backtogher and get it to work, which i doubt you could put some phase change on it and start overclocking it if you get it to 500mhz you would be a hard god :D
I agree 100%...I'm getting tired of seeing this posted :rolleyes:
Status
