what should i do
Bleedblue12345
well i buaght a 7600gt and now im kind of on the fence, should i take it back or not....
cause i have scounged up enough $ to buy a x1800xt, but i was wondering if its better using that 7600gt for a year or so and then buying a dx10 card later..
what do u guys think
Depends on what level of gameplay you want right now... the 7600GT isn't a bad card...however the X1800XT is faster and will render slightly better. Waiting to upgrade is always going to be hit or miss. I personally would take the 7600GT back and get a 7900GT . But if x1800xt is the way you want to go then that's cool too. Nevertheless both will give you better performance than the 7600GT.
And if you have an SLI capable motherboard...why not spring for the 7600 GT in SLI... ;)
