What should I do with my case?
.ReCo!L
Sorry I dont got any pics of my own case but go here to see pics of the exact same case. Its not beige anymore since I painted it a while ago. Im thinking of going down to my local hardware shop and buy plexiglass for a side window and also thinking of painting it black. What else should I do with it?
You need to improve air flow in that case. First thing that will help would be to cut out the pre-fab fan grills and replace them with wire fan grills. You can install a blow hole (or exhaust fan on the top of the case). Also try to think of ways to improve the air intake on the front of the case. A lot of times, you will find that mods do not neccessarily have to improve the looks of your rig, but to improve functionality. One thing that you MUST do before you start to cut any part of the case is remove everything from the case...........the metal shavings created when you are cutting will damage or destroy your computer. A good rule to follow when you are making any cuts, whether for a fan or a window is to measure 2 or 3 times, and cut one time. Once you make a cut, you are pretty much stuck with it. After you make the cuts, remember to thoroughly clean the case before returning the computer components to the case.
