What should i cool? (K8)
M4d-K10wN
(i know this is another newb question, but i really don't know since the computer i use right now is a celeron, and i doubt it needs any heating at all...)
Anyway, i'm getting an Athlon-64 3200+ with a Gigabyte K8N Pro nForce 3 mobo. I already have some of the parts, while others are being shipped (the processor, for one). I bought most of the stuff recently, so i could still re-fund it (except the video card, but it's a good one). Either way, what i want to know, is basicly what i attach a heatsink and a fan to? Or possible either?.. I know i already need some fans/ hsf's,
-one for the power supply (i think i'll go with the stock one, unless it's really noisy)...
-then another for the CPU, i'm getting a Termaltake Venus 12 ( this thing: http://www.thermaltake.com/coolers/venus/rs/a1744.htm )
-Umm... i'm thinking about getting this whole thing for the video card, the stock fan looks shabby and unreliable. :http://www.thermaltake.com/coolers/chipset/a1655.htm
-Then a ram sink for the ram. Any copper sink would do, right? Right????
-Two Fans sucking in front, do those come with the case?? probably not =\
-One fan blowing out the hole on top
-A fan in the wall, one above the CPU, and one above the Video card, should these suck or blow? Blow, i think
What else do i have to keep cooled?
Chipset? North bridge? South bridge? ??? ::eek:
Where's a north bridge btw?? can anyone show it? I have a picture here:
http://www.giga-byte.com/Motherboard/FileList/ProductImage/photo_k8n-pro_10_big.jpg
How do i know it's the NB btw. I doubt it says that on it.
the hsf goes on the processor
if i was u id get a Zalman CNPS7000A-Cu
from wat ive heard the Zalman ZM80C-HP is better than that TT giant II
the fans on the side should blow over things so that wat ever is getting blown all over gets the cool air from the outside,just make sure u have some exhaust fans at the back and top to get all the hot air out
the northbridge is that gold hs that has the gigabyte logo on it
if ur gonna be overclocking get a vantec iceberq4 or sum thing similar to cool it down
