What should be my temp???
joelkyr
Just want to know what should be my temp, my loop runs res-rad-pump-cpu-chipset-res, right now my idle temp is 33c/load is 36c-38c. Should i expect more from my WC? can this temp still be lowered without doing any major overhaul on my current WC set-up. thanks
WC set-up:
COOLING:
Swiftech MCW6000-P
MCW20-P
MCP650
Black Ice Xtreme radiator
QUAD reservoir
10% Swiftech HydrX
I run about the same w/ my Danger Den setup when its im rougly 33-37 and when im stressing the cpu it gets up to 42ish. Mines OC'ed w/ a vcore of 1.8 so i figure its running hotter then it could be.
Joelkr-Are you running at stock voltage or are you OCing at all? That seems slightly high if your at stock specs.
My 2600 M was at 29c idle 33c load at stock specs. Now at 1.95 Vcore its 36/47 .
a QUAD bay res? 4 bays? Thats crazy.
