What should a webserver consist of?
Mikesta
What should a good home webserver consist of to host some images,files etc.. and maybe run some dedicated programs only if i decide for what though.
Do you mean speed wise?
If just for your home, pretty much any low end box will do.
A p200 running win2k will serve static pages.
If you want it to run apps too, it depends on the apps.
Gameservers will need alot more than a simple webserver.
not exactly "game servers" maybe running some dedicated programs aka team speak, ventrilo etc...
I have money to make one but i dont want to spend too much on a webserver.. can someone recommend me a list of parts totaling no more then 200 ? The only thing i got is a case coming in for this.
With 200 bucks you can probably get a good used pc to serve your purposes. You may want to try local pc stores or the newspaper.
Yeah i was searching the fs/ft forum finding some parts.. You think it'd be a big bandwith problem? Just running like SIG images and a couple of files etc, Would it affect my main gaming machine bandwith wise? Is their a way to limit bandwith to that webserver if so how much should I limit it to.
Beware slow machines with teamspeak/ventrillo:
The lag will *KILL YOU* if you aren't running a half-way decent machine.
Heres my build for ya:
Powman j.random beige case http://www.newegg.com/app/viewProductDesc.asp?description=11-145-013&depa=0 $25
Fortron 300w PSU $35
KT400 based mobo $40
Applebred duron 1.8 $42
?gb HD 0-$80 depending on your space needs
GF4MX440 $30-40
256 PC2100 Kingston Valueram $55
3com 3c905c 10/100 NIC (yes get a NIC it will help bandwidth) $10
