what setup should i go with?
Zecora
i would like to go with a dual amd xp setup.
which boards excpet modded xps
i hear the k7d master L but where do i find it?
i am lookiong at spending around 500 for a mobo,2cpus,ram
Yeah the K7D Master is your safest bet... I am told the Iwill MPX2 is the best overclocker, but you might have trouble finding one at a reasonable price.
peace,
OriginalOCer
where do i find the k7d master L they do not sell them on newegg anymore. then where are some reviews on how to mod the xps to mps.
I'm fairly confident that you can find the K7D Master-L on PriceWatch... As for the L5 bridge mod, you should check out 2CPU.com forums... ;) Do a search there should give you the answer. :)
