Box #1:
Windows Vista Ultimate Ed. 64-bit
Lian-Li PC-82 Aluminum case
Corsair HX620w
Gigabyte GA-965P-DS3 v1.3
Core2 Conroe E6700 2.66ghz
4096mb OCZ Reaper HPC PC2 8500 (4x1024mb dual-channel)
eVGA GeForce 8800GTX
Creative X-Fi XtremeMusic
Klipsch ProMedia 4.1
Seagate 7200rpm SATA 750gb (16mb cache)
Sony DDU-1612 DVD-ROM
NEC Optiarc AD-7170A DVD+/-RW
USB devices:
Logitech G5 Gaming Mouse
MS Sidewinder game pad
Saitek Eclipse Gaming keyboard
HP w2408 24" LCD
But at what resolution...I was able to play Crysis with everything set to High. I changed some of the setting in the CVarGroup folder to get some Very High settings in Windows XP. Anyways I have an E6600 overclocked to 3Ghz, and my 8800GTS 640MB overclocked to 630/1000Mhz, I have 2GB of ram. I was able to play the game at around 25-30FPS. Except for the last level playing the boss, at that point I probably averaged around 15.
I'm kinda suspicious of people who are playing on Very High and finding the game playable... is there something you're hiding like "o btw I have shadows on low k... same thing tho?"
I haven't actually had a chance to play the game yet, but I'm finding the "playing at Very High" reports to be encouraging.
1920x1200 noaa/noaf DX10/64-bit
I am afraid I stopped playing at 1650x1080 on my widescreen 20.1"as I needed to put medium shaders due to my 8800 having only 320MB of memory. What a shame as the game looks better widescreen![]()
Hey Brent I got a quick question for you, or to anybody who can answer this. How do you get the 64-bit into your gameplay information. I checked mine yesterday and it said DX10/32-bit but I have a 64-bit system. I thought it was sort of odd at the time but now that I see 64-bit is possible how the heck do I enable it? Thanks
You need a 64-bit OS and CPU, it should launch automatically in 64-bit. If it does not, and you meet the requirements, launch it manually. Go to your Crysis game directory, inside is a Bin32 and Bin64 folder. Go into the Bin64 folder and launch the Crysis.exe from there.
I have yet to launch in 64 bit, i get a black screen and nothing , shortcut or bin64
Seems like post-processing is a huge hit. I can play it great at 1680x1050 with all on very high if I turn post-processing down to medium. All I can tell is gone is motion blur, which I disliked anyway. Very pleased with performance and quality now.
