What S939 Board for me?
Hi this i my first post in this forum
I´m about to buy a 90nm 3200+ but I don´t know whitch motherboard to choose?
I have looked at
Abit AV8 K8T800 Pro
Asus A8V Deluxe K8T800 Pro
MSI K8N Neo2-Platinum 54G nForce3 250
It leaned at MSI but when I looked at the motherboard I saw that my watercooling doesn´t fit on it. I have Dangerden Maze4(CPU,GPU,Northbridge). I live in Sweden that why I only have so few motherboards to choose from.
So it´s between Abit AV8 and ASUS A8V and I don´t know whitch to choose can anybody tell me whitch motherboard that has the most quality and stability is top notch? Becuse I don´t want to overclock much just a bit maybe and how is the S939 with memory compatibility I heard that Abit has problems with it does anybody else have the same problem? Becuse I have ULTRA Dual Channel 1024MB PC3200 DDR 400MHz does anybody know if these work on S939?
Sorry for my english.
Please answer I need knowledge:)
Yes, DDR400 works nice on both (Asus and Abit) 939 setup. I'd advice you to get Asus mobo if you want to get a nice vendor support, mainly if you don't intend to make hard overclocks. This Abit board is very nice too, but doesn't really bring so much improved stability in a comparison with the Asus mobo you mentioned. Beyond all, Asus is cheaper. :D
if you get the abit AV8 with a winchester chip
you will NEED the newest bios on that board or it will not boot and give you a error code 9.0.
the bios version needs to be 15
i just found out the hard way...luckily my cusion had a 130nm chip
this problem is ONLY for the 90nm chip's
its the only board that allows a bootup with a .90nm chip in it, otherwise you may have to borrow a .130nm chip to bootup and then download a newer bios (for the abit board)
also, the Asus Rev2 is rock-solid stable :D
