Using it for computer audio, so it belongs here.
The guys over at AVS forum won't help me, despite 3 bumps.
I bought the Klipsch 300 HD.
I have three questions.
One, my cousin says he's having trouble using his PC's equalizer (These will be for the PC, not for my TV.) to control the audio. . . I have an X-Fi card, will I be able to control the frequencies etc. or will the receiver some how over-ride that?
Two, what's the difference between these (other than two of them use 7.1, which I will Probably use via hdmi)?
http://www.newegg.com/Product/Produ...15238&cm_re=yamaha_5.1-_-82-115-238-_-Product
http://www.newegg.com/Product/Produ...15289&cm_re=yamaha_7.1-_-82-115-289-_-Product
Three, do you have a better suggestion?
