- Feb 4, 2007
I am building a WaterKeg and I don't know what kind of Water Pump or CPU Water Block I should get. I have a Q6600 LGA775. I already have the radiator, and I'm using 1/2 fittings all the way around.
I was looking at getting the Swiftech MCP655-B for my pump. but I noticed that you can get AC powered pumps for less that pump more GPH, but how do they shut off when your PC shuts off if they're plugged in to the wall?
As for my CPU Water Block I have no idea what would be a good block. can you guys help a PC nerd out?
Also, can some one explain to me what is better, from the reservoir to the pump to the radiator to the water block back to the reservoir. Or from the reservoir to the pump to the water block to the radiator back to the reservoir? I've seen both but which route works best?
