Bookmage said:What no pics?
I'm sure people want to see the workshops of the [H]ard modders.
And pics would help new modders identify tools and parts.
Not everyone knows what a "Lincoln Electric Invertec V350-PRO Adv. Process" can be used for![]()
And remember to list what the tools are used for.![]()
- - Just wait, they're coming.What no pics?![]()
Susquehannock said:- - Just wait, they're coming.
The Dremel are nice toys, but woefully inadequate for all but the smaller jobs.
Much better to use pneumatics (air tools). Multitudes more torque.
Don't get me wrong. The Dremel are OK if you are the occasional modder. If you plan to do
a lot of modding it's well worth getting some real tools.
1] - High volume compressor. Looks kind of top heavy with that big twin cyl. pump on the 20gal tank.
But that's the key, no need to wait for pressure to build within the tank to use the tools.
2] - Die grinder with 'double cut" carbide rotary file, reinforced Dremel cut-off disks with the center hole
hogged out to fit a 1/4" shaft, hand files, and some sandpaper. The resulting edges are
smooth enough for a baby's hands.
The above window took roughly about half an hour & 7 disks. Only a small fraction the time it would
with a Dremel. Works on acrylic too - see below ...
3] - die grinder & "double cut" carbide rotary file again.
4] - End result :
Susquehannock said:I have a cutting torch here and would never use it to cut thin gauge metal as in a PC case
because it leaves rough edges & there is a chance of warpage.
But to each their own.![]()
AreEss said:You're gonna get rough edges with a torch period. And whatchoo talking about, thin gauge? Most of my cases are 2mm minimum. 'Sides, I always clamp things down to prevent excessive warp. Just gotta watch that metal like a hawk.
Sheldron said:Let's just say that I don't have enough tools... (is there a such thing as enough tools?)
Short list of some of the essentials:
1/2HP Craftsman rotary tool ( + snake arm attachment )
tablesaws ( 2 )
drill presses ( 2 working, 1 not )
hand drills ( cordless & corded, too many to count ) (oh yea, drawers full of bits all shapes/sizes)
saws, screwdrivers, hammers, wrenches, pliars (again, too many to count)
2 lathes (1 wood, 1 metal)
2 milling machines (1 industrial size, 1 micro-mill)
2 routers (1 hand, 1 mounted in a table)
2 compound mitre saws (10" & 12")
cutting torch
MIG welder
ARC welder
(planing to buy a good TIG sometime soon)
that's just the stuff I can think of without actually going to look (I'm at work right now)
Susquehannock said:Is that the list of tool/equip. you have at home? If so I am envious as I would love to have
a lathe & end mill here. Was a real shock when I had to retire from CATerpillar and didn't have
access to all those cool big machines anymore.![]()
Susquehannock said:Sorry but I think you are mistaken. 1mm maybe, but I seriously doubt 2mm. That is equal to
14gauge. Most cases are made with 20gauge or 1mm from what I've seen. Some cheaper ones 22gauge.
I just don't think a regular cutting torch is well suited for thin metal. Now, a plasma cutter is a different story.![]()
Susquehannock said:Oh, well if you are talking heavy duty server cases that a whole different ball game.
Haven't seen one of the Enermax 910 or 911 personally. Are they Aluminum construction? If made
form 14ga & 12ga steel that's just crazy.![]()
