Still doesn't work.![]()
I didn't rip the files. Friend got them for me from torrent. I use .8.3 Foobar to play my stuff.Mister X said:How about trying that in english so we can figure out why it doesn't work?
What software you using to rip the files and to playback the files?
That should get us started.![]()
All loaded properly.Mister X said:Load the preferances dialog in foobar (ctrl P) and scroll up to the component libraries thing and check to make sure all of the component libraries loaded correctly.
If they did I would suspect the files are bogus.
What kind of message does it give you when you try to play the files?
