what paste to use on RAMsinks?
Hard911
any suggestion on paste to use on RAMsinks and I want it to be removable, I have some ramsinks but don't have any paste to install on RAM chips which I'm watercooling my Video Card, thanks for the help!
I know alot of people around here (including myself) that would suggest against using RAMsinks/heatspreaders, but eh... removable... can't think of anything off the top of my head except maybe a reallly small dot of super glue and some AS5. Small enough a dot of superglue where you'd be able to twist the RAMsink off easily without having to apply too much force I suppose.
arctic silver thermal epoxy, blended with either AS ceramique or AS 5.
if you blend it about half and half, it conducts heat damn well and is removable.
Hard911 said:
isn't it permanent when using proxy or adhesive?
if you use all epoxy, it's permanent. if you mix the epoxy with thermal paste it isn't permanent, and it conducts heat bit better.
