what panaflo to get (all sizes)
ryuji
im going to replace all my vantec thermalflow's and noname fans in my case with panaflo's.. also going to need to replace a 92 mm intake and get a 120 mm fan for my xp-120 im getting...
what i want to know... how quiet is the 120 mm m1a and how loud is the 80mm h1a at 7v consitering the rpm of both are under 3000 rpm they are probably quite respectable at stock.. but i like my computer quiet
What's the best quiet 80mm LED fan on the market?
total:
5 or so 80mm h1a
1 92mm
1 120 mm
(expensive i know... but i think they would prob last a long time...and be quiet or silent)
yep... i got a big case :D :cool:
The 120mm on my XP-120 is very quiet actually. I was pretty amazed....at full spin it makes a little noise, but at whatever speed it runs before i do 8/8 fan speed in CoreCell isn't loud at all....even at full bore it's more than acceptable (but I'm not a silent fanatic). I have an Aspire Blue LED 120mm exhaust that runs off a molex plug and it's definately much softer sounding than that.
If you have an XP-120, yea. That's what I'm using and it's not loud at all...surprised me really. I don't really care about noise (my computer is loud as hell....not Tornado loud, but still loud), but I always like the pleasant surprise of a quite component (like my PSU which is amazingly quiet).
any experience with the other fans, or at least tell me what other fans did a nice ammount of air flow for you and were quiet.. im deciding on what to replace my dieing fans with :rolleyes: :(
I'm most definately not the person to ask about quiet fans haha, seeing as how my machine sounds like a jet engine (okay, not THAT bad, but it's bad enough).
Just a rule of thumb: The smaller the fan, the more noise. I'd love to build/mod my next system with all 120mm fans for effecient airflow / low noise. Not sure about other sized panaflo's since all I've used is the 120mm, but I'm assuming the 80s and 92s can't be too loud, but they aren't exactly pretty.
i dont care about looks really i want somthing i can turn down to 7v when im not gaming and barely be able to hear it from about 6 feet away i like being able to know my pc is on when its quiet in my room..
I wouldn't suggest a Panaflo L1A or M1A. I had one of each and they were fine when holding them while they were on, but when I screwed them into the case it was like an earthquake. Yes I did install them properly, but they made A LOT of vibration which created noise. My case is an Antec Sonata so it's not some crappy case either. So far my favorite 120mm fan is the Enermax UC-12FAB. It pushes out more air at the same dBA level as the Panaflo L1A and is adjustable. Plus it's about 1/2 the cost.
ok.. so for 120 mm i should do the adjustable enermax... now to decide on what to do with 92 mm and 80 mm.. i am toying with 92 mm intake and exaust but blow holes going to remain 80 mms because of space constraints
so far...
1 or 2 80mm h1a (noise problem with this?)
4x92mm 2 front intake 2 rear exaust (but what fan, dont mind fan controller)
1x120 mm edjustable enermax
hmm, seems this Asian Fury replied into about 10 threads with the same msg lol....maybe someone got into his login.
I use the Panaflo m1a
Panaflo 120mm
At maximum setting, it's 35dba, but then again, you do get 87CFM of airflow @ ~2100RPM.
I need to replace my fan controller, I usually run it at ~1000RPM and its silent.
The Panaflo L1A 92mm fan I had was disappointing, surprisingly loud. Antec's 3-speed adjustable 120mm fans are quite nice. Also available with pimpin' LEDs. :D
I actually like that antec 3speed adjustable 120mm fans..
i want to adjust from fan controller.... not a tail for each fan.. i actually DONT want the tails to be on anything but perhaps the cpu fan (the 120)
i have hered that panaflo's are loud at 12v but once you bring em to at least 7v there fine
I would suggest the M models. I have the 92mm H1A and even at 5v it is a little too loud for my tastes. I had 2 H1A 120mm fans and it was FAR too loud me at 5v. Now I have the M1A at 7v and it's perfect.
m1a 120 mm or 92 mm :confused:
