Well I was trying to read up and better understand all the jargan behind the power supplies but it prolly goes a little deeper than I'm ready to go into, so I'm hoping someone will be kind enough to point me in the right direction.
My system (copied from orders)
ASUS A8V DELUXE Socket 939 VIA K8T800 Pro ATX AMD Motherboard
GIGABYTE GV-N76G256D-RH GeForce 7600GS 256MB GDDR2 AGP 4X/8X
OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Platinum Desktop Memory Model OCZ4002048ELDCPE-K
2 CD-RW/DVD-RW
1 Floppy drive ( Don't know why haven't used it in ages)
1 LSI LOGIC MegaRAID SATA 150-4 64-bit PCI SATA Controller Card
4 Western Digital Caviar SE WD2500JD 250GB 7200 RPM Serial ATA150 Hard Drive (Raid 5)
1 Western Digital Caviar SE WD2000JD 200GB 7200 RPM Serial ATA150 Hard Drive (OS Drive)
Thermaltake Xaser 3 case (6 fans with controler, has a light not used, hate this case actually but its what I have atm)
So there you have it, my current power supply is over loaded I know, its a er COOLMAX "EZ Wire" CU-400T ATX 400W Power Supply, I know a lot about PCs but I'm at fault for always over looking the powersupply as others are.
The system above didn't start out that way and at one point i'm sure the power supply was ok but as my system has grown to fit some of the work I do, at least storage wise, I haven't thought to upgrade the powersupply anyway.
So what supplies should I consider? Oh yeah, I'd take a suggestion on a better case too
In any case I'm looking for something that functions well more so than try's to look pretty.
thanks in advanced!
2 CD-RW/DVD-RW
thanks in advanced!
