SomeGuy133
- Apr 12, 2015
So i got this motherboard as discussed earlier on the forums and it should be well known by now that I want an Intel 750 or something like that for my rig. I discussed with cutting corners and doing a RAID 0 with SATA but I think getting an NVMe now is best/simpler.
Performance for me is crucial and the drive needs to work well. I am not concerned with "booting" quickly since my desktop will be on basically 24/7. It isn't a laptop so boot times are irrelevant for me (within reason of course
Price is an issue but i won't go frugal if performance is at jeopardy but at the same time I am totally ok waiting a couple months if a better option will exist or prices will magically drop several hundred.
I am looking for a 1TB drive give or take so my budget is ~1k unless something comes up as with whats stated above.
If I am spending 1k I want it to be basically the best option where i won't upgrade unless those DDR3/4 SSDs injunction lifts and they are affordable. "Me sa want them so badly"
1TB is very important to me since I am always out of space on my 480GB unless It might be a good option to do a 400-600GB drive as OS and 1 TB for movable data. I get really annoyed with the merry go round i do on my drive due to limited space and keeping limited games and programs installed, Do the Intel drives require a full 25% OP? Looking at my drive I only have maybe 40GB of data files so I have a solid 300GB of programs and the likes so the Intel 400GB wouldn't work.
So thats where I am at. Any suggestions?
Oh also what NVMe drives even exist right now? I can only see samsung and intel but maybe I am missing others. I am not all two informed on this topic :/
As always thanks for the help!
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157500
