What muli-tool do you carry?
Status
Not open for further replies.
I've been looking at various models for a multi-tool for work. The only brands that I've seen so far are: Leathermen and Gerber. I basically need: pliers, scissors, a blade, and a couple screwdriver bits.
What multi-tool do you recommend?
I'm going to keep it under $100.
Thanks in advance,
Aaron
Leatherman Wave FTW!
I don't know about the current model but the one I have has lasted me years. :) I like it because it has what I need in a fair-sized package, nothing too big for my hand or my belt.
Yeah, leatherman wave is pretty solid. I guess it depends on what you are using it for, but being an electrician it sure is handy
I always have a Leatherman Micra in my pocket and a Leatherman Blast nearby. The only brand you should consider.
Google for confiscated ones from airport scrrening by the TSA for several dozen of my former ones, since I always forget to take it out before I get in the security line when traveling!
I don't know where this post goes - maybe Firearms and Knives in General Mayhem - but it certainly doesn't go here.
Status
