What motherboard??
landspeed
I have a mobile barton 2500+. I need something that oc's good.
gigabyte GA-7N400PRO2
asus A7N8X-E deluxe
asus A7N8X deluxe
msi K7N2Delta2-Platinum
I'm up to other opinions
Not from personal experience, only from what I've read.
You're going to want
1.) DFI Lanparty NF2 Ultra B
2.) Abit NF7-S (version 2) not to be confused with the NF7-S2
The DfI is about $20 more. The DFI will let you raise the Vdimm more, whereas on the Abit you would need the Booster or a volt mod.
qft, those are your options if you want the best
personally i'd go with the abit just because of brand preference but i know the dfi is most likely just as good
thast a screenshot of my overclocked 2500 XP-M and DFI Lanparty NFII ULtra rev B.
dont get much sweeeter then that
Beware though, once you go DFI, you will never want to go back
http://dfi-street.com/forum/ check out that website for more detailed info
you just LOVE flashing that screenshot don't ya? :)
