What Motherboard?
Look for the P35 boards.
Best premium board is $180 so consider that.
Anyway, go to newegg and search for P35
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030
The premium boards are the Asus P5K Deluxe & Premium, Gigabyte P35 DQ6 and the Abit P35 Pro board and the newer MSI P35 Platinum. (not very familiar with this one, but it is actually cheaper than the Abit P35 Pro)
The lower end boards will give you good performance as well, but they don't have any of the "PREMIUM" options such as Esata, RAID, better cooling, better components, double LAN...
It really depends on your needs!
